Cargo lights stopped working.
twk62390
I noticed that my cargo lights are not working and can’t find the fuse to save my life. Has anyone had any trouble or can anyone direct me where the fuse is? Thank you.
Did you turn off the interior lights? Overhead switch.
Try looking for these fuses on the interior fuse box:
29090
29091
Thank you! I will check this tonight
Did this work for you? I just installed bed lights and they aren’t working. Wondering if it’s a fuse
Use the search, and check out bed light threads. They may have to be activated, after installing.
I’ve searched every set of keywords I can think of to find an answer on this forum and others but haven’t found anything that has helped. I activated/enabled the lights in AlfaOBD using the Security Bypass but they’re still not working.
Figured it out thanks to mdschadler. I wired up the ECM based on looking at the diagram as if it was showing where to put the pin from the plug side. But the diagram shows where to pin it from the wire side. Stupid mistake, I know, but I feel like it’s an easy one to make. Lesson learned and hopefully it will help someone else out too!
I worked on it this weekend & have everything wired. While testing the connection to white/ tan wire in the back seat I must have done the same thing. Any ideas on how to tackle? Was your fuse bad or something else?
*edit* computer had it locked out for voltage irregularity. waited and drove the next day and it reset, turns on again.
