MDS is on all the time unless you disable it every time you start the truck . As Richard320 said , you can turn on the ECO light so you know when you’re in 4cyl mode .Hi. I have 2020 Laramie.
Am i supposed to see option in settings to turn on MDS?
THANKS
Do you have a V6?Is it possible my truck doesn't have MDS? I have no option to disable it and I've never seen the Eco light on road trips.
5.7Do you have a V6?
Thank you, sir. Apparently the ECO light was disabled. When I turned it on, i was shocked at how often it comes on. Drove 3 hours home today and it was on half the time!If you have a Hemi, you have MDS. There is no official option to disable it, but many do by setting their gear limit to 8, which gives you all 8 gears but prevents MDS operation. The gear limit button is on your steering wheel, lower right side (+ & -) buttons. This must be reset anytime you turn off the truck or have shift out of drive (such as from D to R, D to N, etc.)
To see the Eco light, you need to activate it on the options section on your Uconnect screen.
Why do you think it'll damage your Hemi?5.7
Will be using gear selector method from now on until someone makes an reliable hack for this. I buy things for the long-haul so I don't want to have to put a new motor in 200k miles from now.
5.7
5.7
That's exactly what i told my Girlfriends husband when he caught us...It seems to me, if it's been working and you were unaware that it was going in and out until you turned on the ECO indicator, that it's working perfectly. Instead of disabling it, shut the ECO light off again.
BOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!That's exactly what i told my Girlfriends husband when he caught us...
That's why my other car is a supercharged v8 station wagon with 600hp, 680ft lbs of torque (that still gets better MPG than my truck)
Man I wish I could be in ECO mode that frequently.
In your case why would you want to disable it. It has to be doing great things for your fuel mileage if it really is on that much.
And no it will not cause reduced durability too your engine.
2005 E55 AMG. Headers, no cats, 72mm supercharger pulley, double-size heat exchanger, colder plugs, bigger injectors, custom dyno ECU tune, upgraded intercooler pump.AMG C63?
I'm kidding of courseBOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
