Brake Fluid Change
Oldphart
Orange, TX
Are there any issues changing to DOT 5.0 (silicone) brake fluid? This is probably going to be my last vehicle and as I go along, I want to "upgrade" as I am able.
There is absolutely no need to use DOT 5 brake fluid unless you will be track racing your truck where the brakes will get super hot. Also, you can not just drain the current brake fluid and add Dot 5. They are not compatible.
Shives
New England Area
I know I am late to this party. Please understand the huge difference between the two. They are not compatible at all. If you run dot 5, your going to destroy your brake seals, and will have issues down the road.
Andymax
5thGenRams Supporter
Columbus, OH area
