Been doing a bunch of research into what full cat back for my truck. After reading some feedback from few members here who thought the S-type was too loud, I've settled on the touring since I want something that's tame but has a little more "oomph" during WOT.
Finally got my system in Wednesday and it was installed this morning.
A video review will come shortly after for the noise levels. I did however measured the sound level of the stock system vs the touring systemwith my phone, it may not be the most accurate since it is a phone app. But it was done on the same phone and at the same distance etc and I tried to keep most of the variables the same. Hopefully that will give you guys a rough idea of how much more noise to expect.
The following measurements were recorded
1. Cold start - Recorded 6 feet behind the tip of exhaust / @ eye level with exhaust
2. Idle engine right after cold start - Recorded 6 feet behind the tip of exhaust / @ eye level with exhaust
3. Idle inside cabin - Fan speed was on 2. No music.
4. Normal driving thru neighborhood, light accerlation up to 30mph. Inside cab fan speed on 2, no music.
5. Dead stop, hard pull to 45mph. Inside cab fan speed on 2, no music.
6. Cruising speed at 55-60mph. Inside cab fan speed on 2, no music.
1. Cold start - Recorded 6 feet behind the tip of exhaust / @ eye level with exhaust. STOCK SYSTEM
2. Idle engine right after cold start - Recorded 6 feet behind the tip of exhaust / @ eye level with exhaust. STOCK SYSTEM
3. Idle inside cabin - Fan speed was on 2. No music. STOCK SYSTEM
4. Normal driving thru neighborhood, light accerlation up to 30mph. Inside cab fan speed on 2, no music. STOCK SYSTEM
5. Dead stop, hard pull to 45mph. Inside cab fan speed on 2, no music. STOCK SYSTEM
6. Cruising speed at 55-60mph. Inside cab fan speed on 2, no music. STOCK SYSTEM
