reb0957
What is the correct PN blendmount for a 2019 Laramie, I have a V1.
Their website is confusing.
Thanks!
Thanks!
Try using a 2020 or 2021 Ram 1500 instead of a 2019 Ram. You should be able to find more information and pictures that the mount fit.What is the correct PN blendmount for a 2019 Laramie, I have a V1.
Thanks!
I have the exact same one that I used on my Jeep Grand Cherokee, which I then transferred to my Ram. Fit's almost the same except it's a bit lower and not as flush / close to the mirror as I would like. But it works! I haven't wired it up yet as I'm awaiting for the hard wire kit.I had this one on my 2019 and now my 2021. They are all the same and work great.
Aluminum Radar Detector Mount for Valentine One, Standard Series, BV1-2001R
BV1-2001R Valentine One V1 Radar Detector Mirror Mount; Black Anodized Aircraft Aluminum Collar/Body; Steel V1 Holder; VERY SECURE + LOOKS OEM = BLENDMOUNTblendmount.com
Its def worth a shot. I had to mount the part going over the stem of the mirror backwards and then adjust the way the bottom pieces stacked together to get the fit i needed.Great point, let me see if I can switch it up a bit. Maybe I can find the right height. Thank you for the suggestion!
Can you please post pics?I had this one on my 2019 and now my 2021. They are all the same and work great.
