From his post he doesn't have the OPR springs. He can do up to a 2in spacer in the rear. 1in if he had OPR springs.The rears are not adjustable you will not get any lift. The 0-1" means that you can add a spacer up to 1" to create the lift.
Using the stock springs, how high will the rear 5100’s lift? And at what setting to set the fronts to make it level? Thanks guys.
The lift is in the springs. If you don't get new springs you will need to get a spacer which has been discussed.The rears are not adjustable you will not get any lift. The 0-1" means that you can add a spacer up to 1" to create the lift.
The shocks say 0-1" of lift as that is what they will fit without being damaged. The 0" is an OEM suspension (the non-ORG would technically be -1" and the ORG would be 0"). This means that you can lift the rear 2" for a non-ORG truck and 1" for an ORG truck and still be able to use these shocks (as ff13375 said above).
As for what setting to use. Measure from the ground to the center of the fender front and back see what your differents is. Mine non ORP is 2 1/4 higher in the rear. Parts I orderedHey guys, I’ve had my truck for a month now and it’s time for bigger tires. I got my 5100 rears from eBay within 2 days of ordering. 2 sites that said front 5100s were in stock have now told me they are back ordered and the 3rd site of real trucks hasn’t even sent me a confirmation email. But I have some questions. I have a 2020 bighorn night edition 5.7 etorque, No ORP. Using the stock springs, how high will the rear 5100’s lift? And at what setting to set the fronts to make it level? Thanks guys.
The mopar 2 inch lift requires jounce spacers and a different track bracket. For those going 2” plus with Bilstein’s what’s the downside of not adjusting your tracking bracket???As for what setting to use. Measure from the ground to the center of the fender front and back see what your differents is. Mine non ORP is 2 1/4 higher in the rear. Parts I ordered
Front shooting for 3in
Bilstein 5100( setting 5)
OPR front springs
Mopar upper control arms
Rear
Bilstein 5100
2in spacer
Waiting on springs and UCA to come in. I still wanted a little rake. Should still be around 1 1/4 rack give or take alittle.
Track bar bracketThe mopar 2 inch lift requires jounce spacers and a different track bracket. For those going 2” plus with Bilstein’s what’s the downside of not adjusting your tracking bracket???
Your axle will probably sit a little off-center.The mopar 2 inch lift requires jounce spacers and a different track bracket. For those going 2” plus with Bilstein’s what’s the downside of not adjusting your tracking bracket???
Is this setting 3 or 5 I'm confusing myself! PicInstalled today! ORP BTS, tires changed from stock falken wp 275/55/20 to falken wp 275/60/20. Bilstein 5100s setting 3. Did not want to go to aggressive for gas mileage (95% road miles) but wanted more offroad capabilities for camping/hunting.
Measurements stock tires were a bit under 37.5/39.5 front/rear ground to center of fender.
275/60/20s measurements were 38.25/40.25 front/rear
After bilsteins on #3 39.75/40.25
Definitely got close to 1.5" out of setting 3 with ORP. I'm assuming they will break in a bit, but I'm very glad I went with setting 3 over 4 or 5. 5 would be very nose high in my opinion.
View attachment 70604View attachment 70602View attachment 70603View attachment 70604View attachment 70602View attachment 70602View attachment 70603View attachment 70604
It looks like thats on #5 but it doesnt look like the spring seat adapter was installed. Can anyone else chime in? See diagram for detailsIs this setting 3 or 5 I'm confusing myself! Pic
Is that adaptor something that's needed? Should I go back?It looks like thats on #5 but it doesnt look like the spring seat adapter was installed. Can anyone else chime in? See diagram for details
Yes it is neededIs that adaptor something that's needed? Should I go back?
It looks like just the circlip from that angle.I think of you zoom in far enough you can see the adapter. Definitely looks like 5
Yes it is needed
Anyone have a pic with the clip visible so I can look for it?If that’s true, then that would explain the right lift height but wrong setting...
Thanks, I can't imagine they would have missed this it's a shop that literally just does custom wheels tires lifts levels and Window TintDark here already. I can try and get one when it’s light out tomorrow.
