DarkKn1ght
- May 14, 2019
- Location
- Boonton Township, New Jersey
Any luck yet?
Thanks for digging that up, much appreciated. My first guess looking at my truck side-by-side with a fourth GEN is that the spring seat on the fifth GEN needs to be higher for the strut to clear the CV axle.Here is a comparison from another forum. 4th gen on the left, 5100 in the middle, 5th gen on the right. The spring seat is much higher up on the 5th gen strut.
Check out @ksn240 post above... Looks like fifth GEN struts are longer than the fourth GEN struts, but maybe more importantly the spring seat on the fifth GEN struts is quite a bit higher to clear the 4wd CV axle.Any luck yet?
The spring seat is the biggest issue. The length of the strut is pretty close, but the Bilstein on max setting would only give you close to stock height on a 5th gen. If you had some 4-6" coilovers from a 4th gen you could likely get 2-4" of lift that way, but it's probably best to wait on the new components.Thanks for digging that up, much appreciated. My first guess looking at my truck side-by-side with a fourth GEN is that the spring seat on the fifth GEN needs to be higher for the strut to clear the CV axle.
Unfortunately it looks like the highway Cloverleaf of suspension is just a little bit different for the fifth GEN front end. Guess I’ll just have to wait and save more money LOL.
They should be coming soon I would imagine....
I went through this with a '14 F150. I'm out on Bilstein simply because they are waiting for nothing.Here is the responsei received from Bilstein this morning.
Thank you for your interest in Bilstein shocks! We are working hard on the development, engineering and tuning of all kits for the 2019 Ram 1500. At this time we do not have an exact release date but you can continue to check our online catalog to verify if we have any releases for those products yet. I would likely see something come out late this year or early next year - Bilstein Online Catalog
Mit freundlichen Grüßen / Best regards
Jurrian Terpstra
Technical Sales and Warranty Support Expert
thyssenkrupp Bilstein of America, Inc
T: +1 858 386-5900, Direct: +1 858 386-5902, Fax: +1 858 386-5901 [email protected]
thyssenkrupp Bilstein of America, Inc, 14102 Stowe Drive, Poway, CA 92064, USA, www.bilsteinus.com
Well that sucks! I don’t want a cheap puck to level mine and I don’t want to spend $1200 for the Mopar kit either! C’mon Bilstein!!!
I don’t understand the whole “I hate spacers” nonsense. Thousands of lifted trucks use spacers. Every 6” kit on the market for every truck made (with IFS) comes standard with spacers.
It’s fine.
The only time it’s a negative is if you are flexing the truck a lot off road, then using spacers (outside of a lift kit) can potentially allow the truck to over extend in droop.
The advantage to the bilstein is that you get a better strut/shock assembly vs the OEM one, and it’s valved to work with the extra preload on the spring. Don’t get me wrong, it’s a better route but it’s not because there’s no spacer
So with that, you didn’t touch on the OEM rebel bilsteins? Those should be good for 1”, and you could preload the spring for another inch?
No pucks, factory length strut, what’s the rub with this? My truck rides fine stock, couldn’t comment on the ride quality with a preload but I would imagine it wouldn’t be awful if you kept it at 1”. Plus the bilsteins reuse the same stock spring anyways, so aside from the potentially different valving, you have the same setup as 5100s here basically.
The real answer to this is swapping to a front coil over all together IMO. Of course those don’t exist either because everyone’s too busy making crap for the new GM trucks. And people will Beach about paying 1700 dollars for a 2.5” lift.
I was curious about how the Rebels and ORG trucks are 1" higher. So it is via the struts!
