Biggest tires that fit
PB&Ram
Hello. I’m planning on lifting my truck about 4”. What’s the the tallest and widest tires you guys have on your trucks ? I think I’ve seen people having 35x 12 tires on 20x 10 with a -52 offset on a 2.5 lift. Would this need any extra modification to work?
35s on a 4" lift take cutting yes... Especially with a -52 offset. 33s will fit a 4" lift with no to little modifying depending on the offset
I fit 35x12.5 with no cutting or rubbing with a 4" BDS kit. The BDS website lists tire and offset to use. What lift are you planning on? A -54 offset is pretty big. They should hang out there quite a bit.
Where can I go to find the largest tire size without cutting/modification? Or also maybe with a 2.5” lift and level?
Did a quick search of that BDS website on my phone and just saw the 4”, maybe I need to check again on my computer?
Same as BDS then. I have 35x12.5x18 on 18x9x-6 rims. No problems. I will note that the Firestone tires true measurement is 34.5. Most tires are a bit smaller than advertised. I could not see another half inch for a true 35 making a difference though.
285/65R20 on a 2.5 lift/level with factory wheels here. only rub is at full left turn when backing a trailer up.
Same here but with Bilstein 5100's on the 4th notch! Went from a 35x11.50 to a 285/65R20 and now they don't rub at all.
