Biggest tires on stock suspension/stock 20 inch rims
Running Nitto Ridge Grappler 35/11.50/20 on stock rims.
Can you send me more pictures. I want to do the same thing.
My findings - just threw a 305/55/20 BFG K02 onto the stock 20s that are on my limited. Aero and Normal slight scrub full lock right. Going to have to track down and trim as necessary. Haven’t touched Entry/Exit mode yet - I’ll do that tonight and update with pictures as well.
pictures please
I have 275/55-20s on my truck with stock suspension. I am wanting to go 295/55-20 without a level kit. I"ll be OK, right?
I’ll post picks later but everything fits I had a slight rub as I was full turn (to the right)backing into a drive way. It rubbed as I bounced over the three inch curb. I tried to recreate the run and was unsuccessful. So in my book im very happy! So happy I may have a ready lift sst kit to sale as I don’t think I will install it.
Let me know if you sell the sst kit im looking for 1
There are a lot of guys doing different things, I plan on lifting my truck, but for the mean time factory Larime no air ride truck. 33/12.5/20 factory wheels. Or 35/11.5/20 factory wheels. I know once I lift it ill be able to run 35/12.5 or 37/12.5 with no problem. Just trying to see whats best for now.
Has anyone run or can I clear the Toyo RT 35X11.50R20LT on my stock 2020 Ram 3500 Mega SRW with zero rubbing on wheel well plastics or rubbing on radius arm at full lock?
I have the black stock 20's and want to keep them.
TIA!
Hello can you please take a pickture of thé front and rear links revel i Ave thé same and i need to see the set up In place !(i m from belgium ...)
So the question was never answered here. Nobody knows? One guy seems to have fit 33s. would a 34 diameter tire fit on a 20 inch stock rim? No lift?
Hey man I have an 11 ram and with stock rims and I have fit 33’s you just can’t fully turn right or left without spacers I just only turned 3/4 no spacers
I fit 35” on my stock rim but it rubbed 33” would work better still slight rub tho.
Sorry for late response, here are a few pics. Also a pic of what the factory tire and the R/T looked like while at the tire store.
What size are your tires. Truck looks beautiful
Looks awesome does it rub at all after the links installed and did you loose any of the height features?
305/50/20 General Grabbers. Stock everything
I know I'm reviving an old thread. I plan on getting LT275/65R20 installed on a set of Fuel rebels. Truck is stock. Think I'll have any issues?
Super old thread, but curious if you ever put on the 295/55r20s and if they fit ok? I think from your profile you don't have this anymore, but if you did install those tires let me know how they worked out
I actually put 295/60R20s on. That was on my 2020 EcoDiesel North Edition. The North Edition had the Off Road Group suspension, so it sat slightly higher than a standard 4x4. With stock wheel offset, it was absolutely the tallest I could go without rubbing.
No rubbing on control arms and no spacers? I have night edition rims that are +19 offset. Doesn’t seem there's much room between the upper arm and tire so i was considering spacers.
I had no rubbing anywhere. It was very very close at the splash guards, but it didn't touch. My wheels were 20x9 with +18 offset I think. Can't remember the exact offset.
