Biggest tires on stock suspension/stock 20 inch rims
DK04
What’s the biggest tires you can fit on stock 20’s 2019 ram laramie? Anyone have pictures? Looking to do Nitto terragrappler g2
MValdez
North Wales, Pa
Looks good! How’s the ride and noise with those tires?
EvoRAM-... Superb! Now I have never been in a vehicle with "noisey" tires and When I purchased these nitto ridge grapplers I was a bit worried and i can say they are just as Silent as my stock goodyears. Ride quality..... eh, you can notice a slight change nothing severe but highly tolerable. Love These Tires,
hup5150
So the question was never answered here. Nobody knows? One guy seems to have fit 33s. would a 34 diameter tire fit on a 20 inch stock rim? No lift?
Mich thor
I'm curious about this as well,Ill probably run the nexens until they wear out. I thought I saw a metric max size on this forum somewhere.
markymark907
i currently run 33x12.50 all terrians on my stock 20 inch rims, they fit perfect with no rubbing
markymark907
Thank you!
watch out though I do a lot of highway driving and I'm usually on cruise control doing 75(my round trip is about 100 miles) and i lost a 2 mpg but hey they look good and they're great for all the snow months we get in the mid west
19blueram
Guest
Are you sure the sidewalk doesn’t rub on the UCA with those 12.5s ? I run 295-65-20 on stock Laramie rims. which is 35.1x 11.6x 20 and I can barely get the thickest part of my pinky finger in that space.
DK04
I have 33x12.50r 20s on my factory ram limited wheels. Fits great no rubbing at all. I do have pics if you want to see what the Toyo R/T's look like.
Yes please let’s see how they look
Nettag7
North Carolina
Sorry for late response, here are a few pics. Also a pic of what the factory tire and the R/T looked like while at the tire store.
SP97
MD
Another late response. The answer is not quite straightforward because a 33" tire may be wider and fit fine while a 35" tire would need to be more narrow to fit right. So, I think the answer is do you want it to be wider or taller? There are a number of sizes that might be considered the largest tires that will fit. A resource I have used to try to figure this out is the tire size calculator on tiresize.com. The calculator has an offset calculator too so you can also look at wheel offset. I believe the stock 20" wheel is a +19mm offset. I'm not sure spacers are the way to go but it may allow you to go up a size by moving the wheel out a few mm.
Jcall724
2019 rebel aftermarket wheels and tires finally. Wanted a aggressive wide stance this truck deserves.
OUscott1
Oklahoma
Running Nitto Ridge Grappler 35/11.50/20 on stock rims.
SP97
MD
OUscott1 - Nice. That looks good. Any rubbing? Did you use any spacers?
