Technically speaking. You should not use 85.
As Ram Patriot mentioned above.  Older cars, yes and at high alt.
Now in real world, is it going to damage your truck? 99% in my view, no.
If you have 85 and you happen to travel to lower alt., then possible. Again, in my view no. Truck is designed to handle it.
I mentioned way above, hot/cold air/pressure are also factors. e.g. you could take 87 gas from location, and drive to another location, and
it would seem your truck isn't performing as well, with same gas. Generally it would be minor though, unless you did some mods on your truck.
The sensors, computers, etc, in engines today, when working correctly are very good.
If I lived where you do, and it was my truck. I would put 87 though. If there happens to be an issue, it could effect your warranty.
