Best way to lift rear end 3-3.5”?
CG Rob
Hey gang,
Just bought a ‘19 Bighorn non-ORP. I’m looking to lift the front with the RL 3.5” kit, and run 35x12.50’s on the stock 20’s.
My issue is that the RL kit only lifts the rear of the truck 2”. I tow a boat on a regular basis and don’t want the truck to be squatting every time I have the boat behind it. I’m thinking I need to lift the rear to match the front to avoid the squat.
What would be the best way to lift the rear 3-3.5”? Maybe taller springs and spacers? I know I will need longer shocks. Will I need to lower the track bar mount and swaybar links? Would I need to relocate the 4 link mounts?
Thanks!
-Rob
BowersFJ
Zone has 3” springs and 2 diff shocks to match …. Probably need longer links for the sway bar, but if you tow, I would get the Hellwig sway bar, and Core 4X4 links for 3” lift
damram
The Zone 4 inch lift raises the rear 3 inches with springs, and comes with relocation brackets for the upper control arms (where they mount on the axle), a track bar relocation bracket, bump stop extensions, and longer sway bar links.
CG Rob
Sounds good, thank you for your input!
Are these parts available individually or only in the Zone 4” kit?
BowersFJ
You’d have to call Zone directly
