Aren’t bilsteins only shocks though? I feel like you’d need control arms and springs as well right?Bilsteins seem to be the most popular. I went with motofab top hat spacers on the front and the ride is just fine. Cheap and get the job done. Just make sure the tires don’t run the UCAs. You might need wheel spacers
I thought you could get bilstein 5100 leveling struts for the front. I may be wrong tho.Aren’t bilsteins only shocks though? I feel like you’d need control arms and springs as well right?
The Bilstiens are adjustable struts for the front to give you different levels of lift. The rear 5100s are just shocks that don't change ride heightAren’t bilsteins only shocks though? I feel like you’d need control arms and springs as well right?
I have the Mopar Lift kit with Factory 20" Wheels and am running 295/65R20 (35x11.5 equivalent) Nittos. Rides way better than stock.Anyone have personal experience with the Mopar 2 inch kit?
Did you have the Mopar Lift kit added by the dealer after purchase? If so, how much did that run you? I'm considering doing that to keep the warranty intact or potentially getting the Carli Commuter systemI have the Mopar Lift kit with Factory 20" Wheels and am running 295/65R20 (35x11.5 equivalent) Nittos. Rides way better than stock.
I agree, but should caveat it by saying that my personal opinion is eibachs are stiffer than stock ORG and non-ORG if using the full kit with the eibach springs. If not using the springs, then it’s probably close to bilstein, but I haven’t personally tried eibach shocks + stock springs. Fox 2.0 and 2.5 both have an unbelievably good ride, and so does king if the shocks are set up for the intended purpose.Pucks are ok if you're only going for a look. If you really want enhanced ride comfort you need a suspension lift like Bilstein/Eibach/Fox/King/Icon etc. Bilstein and Eibach being the least expensive at about $100 per corner plus installation. At another $300 to $800 for UCA if you choose to go that route.
I agree with all of this.I agree, but should caveat it by saying that my personal opinion is eibachs are stiffer than stock ORG and non-ORG if using the full kit with the eibach springs. If not using the springs, then it’s probably close to bilstein, but I haven’t personally tried eibach shocks + stock springs. Fox 2.0 and 2.5 both have an unbelievably good ride, and so does king if the shocks are set up for the intended purpose.
