Best setup to fit 35s and level?
Starkhaus
Looking to figure out the best setup for a ‘22 1500 4x4 Non-ORP
Looking to be level, fit 35x12.50r18’s and maintain stock comfort with the ride quality.
What setups y’all got that accomplishes this?
theblet
Bilsteins seem to be the most popular. I went with motofab top hat spacers on the front and the ride is just fine. Cheap and get the job done. Just make sure the tires don’t run the UCAs. You might need wheel spacers
Starkhaus
Aren’t bilsteins only shocks though? I feel like you’d need control arms and springs as well right?
PurpleRT
Bilstein struts, readylift 2” leveling kit, org in the back to raise the rear if needed should get you there. Avoid preload spacers. You might still have slight rubbing in the front with the plastic that can be heated and pulled back to clearance.
theblet
I thought you could get bilstein 5100 leveling struts for the front. I may be wrong tho.
The Bilstiens are adjustable struts for the front to give you different levels of lift. The rear 5100s are just shocks that don't change ride height
Starkhaus
Anyone have personal experience with the Mopar 2 inch kit?
Corvus Eight
I have the Mopar Lift kit with Factory 20" Wheels and am running 295/65R20 (35x11.5 equivalent) Nittos. Rides way better than stock.
Did you have the Mopar Lift kit added by the dealer after purchase? If so, how much did that run you? I'm considering doing that to keep the warranty intact or potentially getting the Carli Commuter system
H2OMAN
The O.C.
Pucks are ok if you're only going for a look. If you really want enhanced ride comfort you need a suspension lift like Bilstein/Eibach/Fox/King/Icon etc. Bilstein and Eibach being the least expensive at about $100 per corner plus installation. At another $300 to $800 for UCA if you choose to go that route.
djevox
VP of Creative Thinking
MD
I agree, but should caveat it by saying that my personal opinion is eibachs are stiffer than stock ORG and non-ORG if using the full kit with the eibach springs. If not using the springs, then it’s probably close to bilstein, but I haven’t personally tried eibach shocks + stock springs. Fox 2.0 and 2.5 both have an unbelievably good ride, and so does king if the shocks are set up for the intended purpose.
H2OMAN
The O.C.
I agree with all of this.
