JohnnyTyler
- Feb 10, 2021
It does say that now. However, prior to the apparent update, it only said that the UCA would not work with the 4" lift kits; no mention of the 6" Coilover kits. As mentioned above (see Abrams117), the UCAs were a selectable option on the 6" Coilover kit a while back. So, they changed their minds on 6" Coilover kits. It seems it would be helpful and offer some piece of mind for all BDS customers to know if this change came out of an abundance of caution (since apparently the only UBJ failures have come with customers who also installed the Fox coilovers) or if they have been conducting some testing and discovered some flaw in the UCA design when combined with the Fox coilovers. Also, it is just the Fox coilovers contributing to the problem, or would another brand of coilovers similarly be of concern, say for example, King shocks? And why aren't the stock coilovers with the spacers having similar issues? Is it a certain lift height that is achieve that is an issues (considering that one lift kit will achieve different lift heights based on the specific vehicle equipment that came from the factory and/or any equipment added by the truck owner)? Lots of questions but not may answers from BDS.says right on bds website NOT to use with there lift kits !!!!
- BDS122251 UCA will NOT work on BDS 4" Lift Kits or 6" Fox Coilover Lift Systems
