BDS 3" Elite Coilover for Ram 1500 DT
SoCalSteve
I purchased this kit from BDS (acquired by Fox Factory in 2014) and after install the suspension was bowing (coil rubbi g shock body)...see pic. I am getting the run around from BDS and Fox. They said this happens sometimes and a very reputable local shop (30+ years same ownership and thousands of vehicles went through them to mod) said this is defective. i spent more $$ with BDS because of their no BS claim. i have found this to happen a few other times (Ford and Tacoma kits) with the Fox 2.5 front set up. Anyone ever see this? 1000007992.jpg
H2OMAN
The O.C.
I have not seen this. Other than the UCA's, what other parts does BDS do for this setup?
SoCalSteve
I purchased this kit from BDS (acquired by Fox Factory in 2014) and after install the suspension was bowing (coil rubbi g shock body)...see pic. I am getting the run around from BDS and Fox. They said this happens sometimes and a very reputable local shop (30+ years same ownership and thousands of vehicles went through them to mod) said this is defective. i spent more $$ with BDS because of their no BS claim. i have found this to happen a few other times (Ford and Tacoma kits) with the Fox 2.5 front set up. Anyone ever see this? View attachment 169813
just the UCA, but they package with fox shocks. fox doesn't sell direct
Daverous
Mine did this when the adjusting collar at the top was threaded at an angel. I had to compress the coil, loosen the set screw, and whack it around until it was straight. At least that’s the advice accutune gave me to avoid sending them in. Check and make sure yours is seated properly just in case.
SoCalSteve
yeah...I believe there might be an issue with this suspension kit and the coil. they sent me another one and same thing happened
DownNTexas
Months old, but did you ever get this situation solved? Wanting to pull the trigger on this set up and revisiting owner's experiences on the forum.
mplaramie
I have this kit in boxes ready to go on the new Ram. Interested in the resolution and outcome.
