I’ve got 2020 Ram 1500, with 3.5in Readylift with 35s.
Im about to tow a Uhaul trailer for the first time and I was curious what ball mount I should purchase for this purpose.
Any recommendations would be appreciated!
Hi everyone,
Thanks
Check out this YouTube
Caravan Sway Crash
That video is a demonstration of when the trailer is loaded improperly with too much weight towards the rear. Not enough tongue weight. This swaying can happen even with small trailers.That's a bit dramatic. The biggest trailer UHaul rents is a 6'x12' enclosed trailer. Hardly an issue for his truck.
Yes and no. You also don't want all the weight on the tongue. Needs to be properly loaded. Too much weight in tongue leads to more squat on truck and takes weight off the steer wheels. Which isn't good either.That video is a demonstration of when the trailer is loaded improperly with too much weight towards the rear. Not enough tongue weight. This can happen even with small trailers.
So for Jayhawk and your Uhaul, load the heavier stuff towards the front.
Yea, I was unsure what point he was making.He was implying that a 3.5" lift and 35" tires were going to cause that type of instability.
That trailer was nose heavy because it was loaded with the heavy stuff to the front, as your post said. The second load there was very little squat because it was more evenly loaded, and despite being a heavier load, it towed better. being leveled doesn't have as much to do with it as how the trailer is loaded, and the hitch used. I probably could have used a 4" drop instead of the 3" drop my dad had and it would have helped more. But that's what I had to work with.I didn‘t say “all the weight on the tongue”.
Yea I saw a picture of your truck with a loaded enclosed trailer that you posted not long ago.
Looked fairly unsafe. I think mainly due to your mostly leveled truck.
This was with empty trailer. Second load didn't have any more squat than this picture. And was these two Cub Low Boy tractors with belly mowers.I didn‘t say “all the weight on the tongue”.
So you are saying if your rear end doesn't squat you loaded the trailer weong? OooookaaayIf it didn’t have any more squat from empty trailer pic, to loaded trailer “being a heavier load”,
then either you are mistaken, or their was NO tongue weight increase after loading with “heavier load”. Loaded incorrectly, Should have quite a bit more.
Not entirely, but they will contribute. Maybe enough to push a marginal situation over the edge. Or maybe I'm overly cautious, but I haven't needed to be washed off the pavement.He was implying that a 3.5" lift and 35" tires were going to cause that type of instability.
I get that, but you also don't want any more squat. You can still get the same 10-15% of load on the tongue without causing excessive squat, like my first load. Wish I would have e taken pictures of the second load, but didn't.Hey you are catching on.
Your tongue weight should be 10 to 15% of TOTAL trailer weight.
More load, 10-15% of load more tongue weight, more squat.
I honestly thought everyone knew that.
Surprised you haven't told me I needed a load leveling hitch. That was most of the responses I got on the 5th gen Facebook group when I posted the picture.First you say “don’t want any more squat”
Also, “can still get the same 10-15% of load on tongue without excessive squat”
Earlier post “didn’t have any more squat “ from unloaded trailer vs loaded trailer.
Which is it.
If you “don’t want any more squat”, you better just get groceries with your truck.
Properly loading a trailer with a load WILL cause squat.
So to address the 10- 15% without excessive squat. A lot of people address this with rake, heavier springs, airbags, or sometimes a combination.
If you are hauling and or towing a properly loaded trailer, it will have some squat (no airbags).
It should not be a goal or practice to control squat with the loading of the trailer.
