What style connectors do your new lights have?Hello fellow ram owners, I’m needing help on the wiring for adding aux light for reverse. I recently bought the curt harness and swore I saved the thread where I got the idea but I can not find it.
If any one can help me I would appreciate it!
Not sure which one you want.Hello fellow ram owners, I’m needing help on the wiring for adding aux light for reverse. I recently bought the curt harness and swore I saved the thread where I got the idea but I can not find it.
Sorry to tell you but that's not the right Curt harness. You want the one that has a 7 pin on the end, not a 4 pin. 4 pin only has tail, right turn. left turn, and ground. 7 pin adds reverse lights, brake control, and 12V charging.Hello fellow ram owners, I’m needing help on the wiring for adding aux light for reverse. I recently bought the curt harness and swore I saved the thread where I got the idea but I can not find it.
Maybe looking for this....Hello fellow ram owners, I’m needing help on the wiring for adding aux light for reverse. I recently bought the curt harness and swore I saved the thread where I got the idea but I can not find it.
This is it thanks!Sorry to tell you but that's not the right Curt harness. You want the one that has a 7 pin on the end, not a 4 pin. 4 pin only has tail, right turn. left turn, and ground. 7 pin adds reverse lights, brake control, and 12V charging.
This thread is probably the one you wanted
Added some reverse lights today
Added MICTUNING Flush Mount Led 20W Flood Cree led lights for reverse lights today using the Curt 56584 and a 5 pin flat trailer side plug. No cutting into any factory wiring.5thgenrams.com
Thank uMaybe looking for this....
Tailgate light with 4pin with reverse light
New here, sorry if this is posted somewhere else but I couldn’t find it. I bought a tailgate light bar. I can’t find on hear or a reliable source using google; a wiring diagram for the tail light connector. I’m trying to find the power wire for the reverse lights so the light bar will power on...5thgenrams.com
Correct me if I’m misunderstanding the install. From what I gather is I tie the curt adapter into the oem harness then use a flat 5pin connector and wire a ground and reverse power source to my lights??Sorry to tell you but that's not the right Curt harness. You want the one that has a 7 pin on the end, not a 4 pin. 4 pin only has tail, right turn. left turn, and ground. 7 pin adds reverse lights, brake control, and 12V charging.
So I need to tap into the black/ reverse and white/ground correct?Maybe looking for this....
A 4 pin has no reverse light feed. Period. A 5 pin or a 7 pin willCorrect me if I’m misunderstanding the install. From what I gather is I tie the curt adapter into the oem harness then use a flat 5pin connector and wire a ground and reverse power source to my lights??
Or buy the one from Vice Design I linked aboveSorry to tell you but that's not the right Curt harness. You want the one that has a 7 pin on the end, not a 4 pin. 4 pin only has tail, right turn. left turn, and ground. 7 pin adds reverse lights, brake control, and 12V charging.
Right I’m clear on that I am returning the harness I got and getting the correct 56584A 4 pin has no reverse light feed. Period. A 5 pin or a 7 pin will
The way it works is to plug a harness into the backside of the 7 pin connection. Then you can cut the wires you don't want or tie them out of the way or whatever and use the black and white wires to power your auxiliary backups. White is ground, black is power.
Yea I appreciate u adding those to choose from but I have all the necessary items to make my own at half the price thank you though bud.Or buy the one from Vice Design I linked above
I found the correct Curt harness for 30 bucks and returned the other one to Amazon. No biggie and I appreciate the inputYou can still use that harness and just splice into the 7 pin wires instead of trying to pull off the 4 pin. The whole point of using that harness is so you don't cut up any OEM wires, so if your wiring doesn't work you can take it back to stock without any modifications.
But yeah, if you're trying to attach a plug to the 4 pin connector you'll need to return that harness for a 5 or 7 pin to get the right power source.
