Aux lighting help
1BADRAMLIMITED
Oklahoma
Hello fellow ram owners, I’m needing help on the wiring for adding aux light for reverse. I recently bought the curt harness and swore I saved the thread where I got the idea but I can not find it.
If any one can help me I would appreciate it!
What style connectors do your new lights have?
I bought this one and the splitter harness to connect two 2-pin duestch style light pods.
Splitter harness
1BADRAMLIMITED
Oklahoma
My lights just have a red and black lead on them. I’m pretty good at soldering so I bought some 2 pin deutsch connectors a while back and have a spool of wire.
Jako
Borough of Parks
Not sure which one you want.
Richard320
Sorry to tell you but that's not the right Curt harness. You want the one that has a 7 pin on the end, not a 4 pin. 4 pin only has tail, right turn. left turn, and ground. 7 pin adds reverse lights, brake control, and 12V charging.
This thread is probably the one you wanted
Littlejoe81
Illinois
Maybe looking for this....
1BADRAMLIMITED
Oklahoma
This is it thanks!
1BADRAMLIMITED
Oklahoma
Thank u
1BADRAMLIMITED
Oklahoma
Correct me if I’m misunderstanding the install. From what I gather is I tie the curt adapter into the oem harness then use a flat 5pin connector and wire a ground and reverse power source to my lights??
1BADRAMLIMITED
Oklahoma
So I need to tap into the black/ reverse and white/ground correct?
Richard320
A 4 pin has no reverse light feed. Period. A 5 pin or a 7 pin will
The way it works is to plug a harness into the backside of the 7 pin connection. Then you can cut the wires you don't want or tie them out of the way or whatever and use the black and white wires to power your auxiliary backups. White is ground, black is power.
Or buy the one from Vice Design I linked above
1BADRAMLIMITED
Oklahoma
Right I’m clear on that I am returning the harness I got and getting the correct 56584
LaxDfns15
Memphis, TN
You can still use that harness and just splice into the 7 pin wires instead of trying to pull off the 4 pin. The whole point of using that harness is so you don't cut up any OEM wires, so if your wiring doesn't work you can take it back to stock without any modifications.
But yeah, if you're trying to attach a plug to the 4 pin connector you'll need to return that harness for a 5 or 7 pin to get the right power source.
1BADRAMLIMITED
Oklahoma
I found the correct Curt harness for 30 bucks and returned the other one to Amazon. No biggie and I appreciate the input
