chuck01835
- Jan 13, 2021
My 2021 ambient switch doesn't seem to do much of anything. Also very low cluster level unless rotated to full!
Thanks
Chuck
Thanks
Chuck
LOL I've only had my truck for a month. I remember the first time I drove it at night and didn't know about the dimmer switch controlling the 12" infotainment screen. That was blinding at night.Same way on a 4th Gen, same as my inlaws Town and Country, its a Chrysler thing. The guy running the dimmer switch department is an idiot. Off, dim, and blinding should not be our options
When you set it right before it clicks, and you have your headlight switch to Auto, it will automatically dim the dash and infotainment screen when the headlights turns on. It also dims everything when you manually turn on the headlights.So odd, I used to be confused/annoyed by this. Then I realized that if I set the dimmer to just below fully bright (like right before it "clicks" into place for full on brightness) it's perfect. It seems to adjust the brightness based on how bright it is outside. I'm very happy now.
