Biga
A little brake torque and disable the traction control and you can do one like this.
			I replaced all, both upper and lower. Better traction in the rain as well.I've heard of the Core 4x4 control arms helping. Did you replace all of them or just the lower? I get wheel hop with just one wheel spinning turning from a stop. Quite annoying and cant be good for the differential.
I went with Tier 3. I thought going to Tier 4 might have been over kill - LOLDid you just get the lower control arms? And which version?
Had a Titan. Can confirm. Loved that truck.The amount of times I launched my Titan getting my tunes dialed in... Spirited driving "every once in a while" isn't even enough to consider. Now, if you're brake torquing and just burning out your brakes that's a different matter, but I had several hundred 0-60 and 0-100 launches in my Titan. Most of those when it was over 100k miles, and it ran better when I traded it than when I bought it new.
The new hardware isn’t necessary is it?The Core 4x4 are made incredibly strong.... NO Flexing and when you feel and see the difference in the construction, weight and the bushings - its a little unsettling to think, "why didn't this come with a stronger setup". But this is a great upgrade and installation is about two hours... maybe 2.5 hours to do them all. You will need to torque them down, i think its 100lbs torque... I think. They also come with a great warranty. If you have a theme color, they will powder coat them for you. Its an additional charge for that.
Hope this helps.
