Grayman5752
Trying to decide what tires to run. Seems like most have 35x12.5R22 but I want to see if 285/55R22 is a size worth considering. I’m going to be running a Mopar 2” lift, so bonus points to those who have that combo.
Yes I just put on on Saturday just had th remove mud guards
Truck is dirty
Just got home from work
There is no lift or leveling kit
No rubbing at any height
Was told not to do the g2
The ridge grablers run smooth
Truck is dirty
Will do just don’t have the truck till Friday still traveling for workHey bro, can you do pic in Exit mode and OR2 from the side??
I'm definitely interested in this too. Thanks in advance.Will do just don’t have the truck till Friday still traveling for work
Wil P, how did your tires work out, any issues? I’m looking to order some as well, but want to make sure there are no fit issues. Planning on a leveling kit as well as the tires, so I’m hoping they clear.I'm definitely interested in this too. Thanks in advance.
did you go with 35s or 285/55So I pulled the trigger on them. 2” Mopar lift with additional 1/2” Motofab spacers up front. Installed the Hellwig rear sway bar while I was at it. Absolutely love the look and ride of the truck, more than when I first got it. Feels how I think a “luxury” truck should ride.
Sorry, are the 1/2" Motofab spacers a coil spacer for lift or wheel spacer for clearance?
Thanks!
