Kaz
For our order its the wife's truck, and I like to mash the gas (her truck is a highway queen). We don't offroad much and I don't like to have a single tire spinning in poor traction scenarios. Anti-Spin was the way we went.
Anymore info on this possible lsd Locker situation? I have a rebel now but I really liked the lsd on my last big horn with the mixed snow and ice patches here in WI/MN.
Yup. This ^^^Anti spin is just clutches and gears. And works well for your everyday application. The anti spin will let you make turns without skipping the other wheel, but when it senses one slipping it engages the clutches and both spin. Nothing electronic.
The locker if you engage it both wheels will be locked together and will not give. So of you on the road and turn with it engaged the inside tire will slip while turning
Absolutely not. e-locker is for slower speed, off-road use. I believe it will disengage automatically after 25 or 30 MPH.Can the elocker be ran daily at traffic speeds (55 to 60)? Or just slow applications?
I am glad Ram offers the 4 wheel auto option. It helps in varying on road conditions in a way 4 wheel locked options do not, inspiring confidence while driving in bad weather. The elocker in my opinion should always be chosen over the limited slip option. It brings sure traction to the rear axle.
Limited slip by using clutches begins to deteriorate with time and cannot be properly evaluated for wear without a teardown for a visual inspection and may fail in a time when it is needed. My view is why choose a wearing option of the clutches when the elocker,in theory, should last as long as the differential itself. Of course, any mechanical system can fail at any time but the clutches of a limited slip system wear with a certainty that is guaranteed.
Due to the 4 wheel auto option, traction is automatic and replaces the usefulness of a limited slip as a smooth transition while driving in quick changing, common bad weather conditions. The elocker provides sure traction under more severe conditions that a limited slip cannot offer.
I will now climb down from my soapbox knowing some folks will defend the limited slip option and they certainly have their reasons for doing so. YMMV and my reasons stated above were developed during my years of off roading and general street driving in AZ and Colorado. Of course, the above comments refer to a four wheel drive truck only and with a two wheel drive street driven truck (ugh) one might prefer a limited slip in which case a true trac would be a great option IMHO. Safe travels to all this winter!
. Well said! I was struggling on which to choose when ordering, but this was the exact reason that I finally went with the locker.It would be nice to know you can lock them because if you're struggling for traction in 4auto, you're past anything the anti-slip is going to help with.
It's just a misprint. No mysteryAll great answers but still a mystery why the list it as electronic actuator vs just saying limited slip.
I’ve posted in the Rebel Trx section. My diff digs both tires into snow/ice.
It's just a misprint. No mystery![]()
