Yes its recommendedAre you guys leaving the plug out of the box?
I left the plug in for now. When the weather gets cooler I will take it outAre you guys leaving the plug out of the box?
When its hot is when you need more airflow since the air is not as dense.I left the plug in for now. When the weather gets cooler I will take it out
With the plug in it pulls only from the front of the truck. With the plug out it pulls a lot of hot under hood air. S&B said to run it without the plug unless it is very hot outside. We are 95 degrees today so I figured that qualifies as very hot outsideWhen its hot is when you need more airflow since the air is not as dense.
I want one of these so bad but California don’t allow it. Anyone have any idea what we can do to get this here.
