Mpickwith
- Mar 7, 2020
Another headlight post, I know! I searched though and couldn’t find what I’m encountering.
I bought some used OEM LEDs because I was unhappy with the AlphaRex’s I had. My left side low beam went out and even with a new bulb it wouldn’t work so I figured it was just an issue with the headlights. I installed my OEMs today and come to find out, the left side low beam doesn’t work!
The other thing is the left side turn signal is very dim, to the point you can’t even see it illuminated but it worked fine on my Alphas I had installed. Could that be a bad module?
I used the retro shop harness for my install also.
