Alpine sub swap to HK
jsimon26
I just picked up an OEM HK 10” sub enclosure from someone locally for $50. I was thinking that I could just swap it out from my Alpine 8” one to see if it sounds any better. The problem is, the plugs/wires are different.
The Alpine one is a 5 pin and the HK one is just a 2 pin. Is there any way to swap this in?
Cesar592
I did it and it's better and in reality they are just occupies +and- I think the 6 leftovers are as if they were the tweeters of the front doors
jsimon26
So did you just splice the connectors? Do you have any pictures of the wiring?
Cesar592
Yeah, I put it together but I don't have any photos because I already removed it because I made another update and I installed the net audio one, which is good.
jsimon26
The behind the seat one? I’ve been looking at that, how’s the bass?
Nehal51086
Charlotte
I just installed mine as well, unfurtlay they forgot to add the ANC bypass (which they sent to me right away) but in mean time i had to reinstall the seat for the kids. need to pull it back out to tweek the amp. Where do you have your set at?
Cesar592
which one did you install
