Alpine sub swap to HK
jsimon26
I just picked up an OEM HK 10” sub enclosure from someone locally for $50. I was thinking that I could just swap it out from my Alpine 8” one to see if it sounds any better. The problem is, the plugs/wires are different.
The Alpine one is a 5 pin and the HK one is just a 2 pin. Is there any way to swap this in?
I did it and it's better and in reality they are just occupies +and- I think the 6 leftovers are as if they were the tweeters of the front doors
So did you just splice the connectors? Do you have any pictures of the wiring?
Yeah, I put it together but I don't have any photos because I already removed it because I made another update and I installed the net audio one, which is good.
The behind the seat one? I’ve been looking at that, how’s the bass?
I just installed mine as well, unfurtlay they forgot to add the ANC bypass (which they sent to me right away) but in mean time i had to reinstall the seat for the kids. need to pull it back out to tweek the amp. Where do you have your set at?
which one did you install
