Its pretty easy, I will try tomorrow to write something to step you through it.How do I get it to actually start the truck and not just open the ram skill?
Just don't have time right now.
I got mine working again, too much experimenting
Tom
When setting up the routine, after clicking on "add action" don't click on skill, click on "customized" and type in "ask Ram to start my truck".Its pretty easy, I will try tomorrow to write something to step you through it.
Tom
Makes sense. Do you have to add the “Ask ram….with voice code XXXX”When setting up the routine, after clicking on "add action" don't click on skill, click on "customized" and type in "ask Ram to start my truck".
I didn't but I also set it up originally to not use the voice code. If you get what I mean.Makes sense. Do you have to add the “Ask ram….with voice code XXXX”
Thanks! I’ll give it ago todayI didn't but I also set it up originally to not use the voice code. If you get what I mean.
You can disable the voice code in the Ram app - go to Settings menu->Account->Application Settings->Virtual Assistant. You can disable the voice code there.Makes sense. Do you have to add the “Ask ram….with voice code XXXX”
When you say the ram app…Uconnect? Or in Alexa?You can disable the voice code in the Ram app - go to Settings menu->Account->Application Settings->Virtual Assistant. You can disable the voice code there.
It's a separate app on your phone. Mine's an Apple, so Apple app store, search for Ram app. I assume there's an equivalent app for Android users. Once you have the app on your phone, you have to link your Alexa account to your Ram account so they can talk to each other.When you say the ram app…Uconnect? Or in Alexa?
