AirRide Levelling Kit Ready Lift - Questions
Ordered from here:
Bilstein
I ordered my ReadyLift last night.
Ordered from here:
Bilstein
Says there’s 2 more in stock ;). It’s already shipped and should be here by Friday.
As for tires, I’ll likely go with the 305/45/22. Truck has 3.21 gears and reading around this forum has me questioning their ability to handle 285/55/22 😂. I’ll be waiting for Mopar’s buy 3, get 1 free deal though to purchase the tires.
oooh haven't heard of that, when does that deal normally kick off?
I’m not sure, but I was under the impression that it is a recurring event through the year.
Just left Total Chaos Fabrication in California today. They took my vehicle in as a Research and Development partner and we installed Air Suspension Compatible Upper Control Arms. Full clearance at full droop with 2” spacer and adjustable air links installed. Accommodates 37” tires! See pics below and follow me on Instagram for updates. Lots of air suspension performance parts on the way!
Instagram: @the_rebel_voyager
I wish that I had come across your response sooner! What size wheel/offset/and exact tire size were you able to fit 37s? Looking you up on Insta now too.
Well hopefully someone here can give some advice on the setup.
I had the ready kit on my 2023 Limited. No issues after being on for 40,000 miles. Brought another truck and sold that one.
IMG_7952.jpegIMG_3089.jpeg72220386929__390F8C75-C524-4904-BC2F-182D561CC663.jpeg72220397737__E9AFAA0A-E368-4D5B-AC63-0B28FFDB4BD5.jpegI have the day star and revel links on mine, photos show different ride heights. I replaced stock 22s with Fuel 18s with -18 offset and 35x12.5x18 BFGs. I have ribbing when wheel is turned all the way. Not sure if adding wheel spacers would help that, or if I should just use a heat gun to adjust the plastic well liners. I put these on at about 45k mi. I am not at almost 80k. Lost about 3 mpg when cruising at about 75. I want to replace the UCAs to prevent any potential issues. I’m just not sure on which route to go. I eventually want to do the air delete that I keep seeing. I’ve had the rear bags replaced already and it’s looking like my front may need to be replaced as well. Seems to have a leak on front diver bagour line
