Airlinks; Yes or No?
Hampton Roads
Just wondering what's y'all's opinions on installing Airlinks? I'm a fan of a more leveled look. This is my first vehicle with air suspension. So my knowledge of it is basic.
Any help or insight would be greatly appreciated!
mikeru82
5thGenRams Supporter
The Palouse
I had them on a previous truck but didn't transfer them to our current one. I like the leveled look but they did affect fuel economy a little. I may end up installing them eventually though now that we aren't driving the truck as much. Just know that they made the OR2 setting unusable.
Pgathomas
I have airlinks and love them. My tire change impacted mileage if anything. Ride is still smooth, I have the or1 setting as normal and my or2 is now or1, if that makes sense. Essentially, I still have or2 but the switch thinks it is or1.
mikeru82
The Palouse
Mine wouldn’t go to OR2. I would get a message about the air suspension system overheating. What you’re saying about OR2 being OR1 doesn’t make sense unless you lowered your truck with links. Maybe I‘m just not following what you’re saying.
Pgathomas
I struggled for a bit understanding it and still with communicating it…
So essentially, when you install the links you are essentially tricking the system to read “normal” as a higher setting… for me, I set the links at the or1 lengths. So my air system, because of the links settings, when enabled after installing, make the adjustment to the perceived “normal”, which is actually or1. On my switch, when I raise to or1, from the new “normal” it is actually raising to or2.
Based upon the switch to raise and lower, entry/exit is now old aero….aero is now old normal… normal is now old or1… and or1 is now old or2.
Did I lose or2?…. Only if you ask the toggle to raise and lower…. since or1 is now the new or2…
I hope this helps
1BADRAMLIMITED
Oklahoma
I have links but i am soon doing this kit.
From My experience the links do level but will result in losing your highest setting and creates a rough ride.
Hampton Roads
Did you get the complete level? Raise the front 1.5in and lower the back .50in or did you get just raise the front?
Pgathomas
Truck looks great!
Pgathomas
I got the front and rear links. I adjusted the rear 6 turns shorter (raises the rear) and found that the front links are preadjusted prior to shipping. I initially put on just the front but liked the look of the truck with the rear adjusted with the front better.
Hampton Roads
I just ordered the leveling kit. Raise front, lower rear. When you installed them did you jack the truck up and remove the tires?
Pgathomas
No, you do not need to remove the tires. Go into settings and place air suspension in tire jack mode… having the setting in normal prior. You will get a message that sir suspension is disabled. From there remove links one at a time and replace with each removal with the Airlinks. Takes about 20 minutes. Super easy. When done, go back into settings and enable air suspension… start the truck and adjustments begin. Enjoy
Hampton Roads
Thank you for the info. I really appreciate it
