Airlift 1000HD install
Creep0321
Bottom line, use the T fitting or do individual a schrader (edit) valves for left and right?
Rick3478
NW OH
Spell checker gone awry? I think you mean schrader valves. Anyway, it's a personal choice depending on how you want to use. If you want the option of compensating for an unbalanced load, you can install individual valves and/or dual compressors. A lot of users, who just want to pump up the rear suspension a bit for towing, go with the tee and/or a single compressor.
Croaker
California
With a tee, wont air go from one bag to the other when you go around a corner?
Creep0321
Yea I was tired. Fixed the original post.
Creep0321
This was one of my concerns, the other being with individual schrader valves, if one develops a leak or pops while towing could that create an unsafe situation?
Creep0321
Also when connecting the WDH, what should the bags be at (PSI)? Inflate prior to or after connecting trailer?
Rick3478
NW OH
Yes, some. Small air lines limit how fast that can happen. For bumper hitch towing, most of that load is near axle level, so not much effect. Cargo in the bed is higher up and will cause more tilt. Heavy duty sway bar like Helwig can help with that. Or go with independent bags if that sounds like your application. Go slow around corners anyway if towing or hauling.
Rick3478
NW OH
With individual schrader valves, if one develops a leak or pops while towing could that create an unsafe situation?
Yes, that could happen.
Some people are of the opinion that you don't need WDH if you have bags or helper springs. I don't agree with that in most cases. There's a science to it, discussed at length in other threads. Bag maker may have charts or graphs to help you with actual numbers, based on trailer/tongue weight, and you should have access to a scale that can weigh truck and trailer per axle. I think most of the inside-the-spring bags recommend inflate first, theory being that it is less likely to tear the bag than inflate after.
Creep0321
Install complete. Took just over an hour. Went with a single path install using the T fitting, schrader valve mounted next to license plate. Currently sitting at 30 psi for 24 hour leak check.
Creep0321
I fully intend on using the equalizer 4 pt WDH in addition to the airlift1000HD. Was also considering the hellwig sway bar as well. And I’m staying on the smaller side with the trailer being a Imagine 2400BH.
Creep0321
Few photos.
Creep0321
My neighbor ran a two schrader system on his and we drilled out the license plate screw s and mounted them there. I just want to make the nut and washer black so it blends in more and I’ll be happy.
Creep0321
Also for those that had the same question as me. I just spoke to a tech with airlift. His recommendation was to measure the height to the rear wheel fender with 5psi in the bags. Then increase air to 35 psi. Then hook up the WDH, then adjust the air as required to get close to that original measurement.
Belvedere
I didn't notice much actual lift with these bags, but definitely rides different and doesn't sag as bad.
I leave mine at 45psi all the time. Coupled with a Hellwig bar on the middle hole it handles great loaded or not.
I chose individual valves through license plate. Having them tied together can cause some odd things to happen offroad. Maybe not so much with in spring bags as standard frame mount bags, but oh well. If I were airing up/down often I would tie them together with a ball valve, so I could air them up together, but then block flow between.
