Good response. This is also true for non-Rebels that have both air suspension and Off-Road Group. Trucks that don’t have the latter ride 1” lower in Normal mode and have 5 air suspension instead of 4 (Off Road 1 and 2 instead of just “Off Road” mode).From someone with air ride, this is applicable for the Rebel but very similar to other trims:
The rebel has 4 modes: Entry/Exit, Aero, Normal, Off-Road.
The new air system as opposed to the old system (which was junk) runs on an closed loop nitrogen system, negating the issue of air freezing in colder climates as others state on the forum - I'm actually looking for someone with a '19 to post up a cold/hot weather issue so far.
The truck rides great/smooth in Aero - stiffer in Normal - very stiff in OffRoad.
OffRoad will auto lower to Normal or Aero (depending on where you left the system last) after 27mph as OR mode is maxing the suspension geometry for daily driving.
There's also a setting for 'Auto Aero' which will lower from Normal > Aero at 67mph+ and raise back to Normal below 27mph.
Entry/Exit will auto raise after 17mph to your last setting (Aero/Normal)
I've also owned many air ride equipped cars and trucks in the past - air is not something to be scared of unless you don't understand how it works
Last Sunday my truck was completely dead in my driveway.
This is unfortunate. You sound pretty bitterIts the same system as the old one. My 2016 was close looped with nitrogen. In the winter the bags leak and once the nitrogen is depleted it brings in outside air from behind the tail light. That air has moisture and freezes up the valves. Its why i traded my 16 in for my 19 with no air ride and i 100% regret my decision. My 19 has had a bunch of issues that shouldnt even be a thing. Should have just spent the $2k and swapped the air ride out for regular suspension. Ill never buy another ram again.
Wife’s always rightBuying a $67,000 truck to replace your other $65,000 truck that had issues and having issues with the new truck will do that to you. Should have listened to the wife and bought a Denali
It’s actually not the same system, but that’s beside the point. Sorry to hear about your continuing issues!Its the same system as the old one. My 2016 was close looped with nitrogen. In the winter the bags leak and once the nitrogen is depleted it brings in outside air from behind the tail light. That air has moisture and freezes up the valves. Its why i traded my 16 in for my 19 with no air ride and i 100% regret my decision. My 19 has had a bunch of issues that shouldnt even be a thing. Should have just spent the $2k and swapped the air ride out for regular suspension. Ill never buy another ram again.
Last Sunday my truck was completely dead in my driveway. Battery was showing 5.5 volts. After charging battery and starting truck the suspension went into entry/exit mode and would not raise at all even though the air pump was running constantly. Warnings popped up saying "service air suspension immediately " and that the system was overheated. Truck towed to dealer yesterday. No results yet
Dealer called and said one of the airbags was collapsed and they are ordering a new one. Battery checks out ok...but I just charged it so of course its ok...a little worrisome because the truck has never been off road and or towed...Hmmm Be a week before I get it back.
