Tom488
Just wanted to post this here, in case anyone else goes looking for the source of this message on the EVIC when trying to adjust their air suspension.
I installed some mudflaps, and to make life easier, I put the truck up on the lift (frame lift, so the suspension hung freely). Afterwards, I had the above msg., and couldn't bring the truck down from it's Off-Road setting (where I had put it, to make positioning the lift arms easier).
Apparently, lifting the truck (maybe lifting even one wheel) automatically puts the truck into "tire jack" mode, which effectively disables the air suspension. You have to go into the uConnect Settings menu, into Suspension, select 'Tire Jack Mode', and turn it back off - your suspension will resume functioning. According to the manual, tire jack mode will also be turned off by driving the vehicle - but the manual never said anything about automatically entering this mode when the truck is hoisted, nor could I find any explanation for the "temp. disabled" msg... so it took me a minute to realize it was in tire jack mode.
Hopefully, this helps someone... I really thought I FUBAR'd my air suspension for a few minutes there![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
