Moonlightboater
- Aug 25, 2021
Well did not do my due diligence before getting my Limited. I looked at the system and it sure enough is a closed system. So if you do develop a slow leak, it is not as easy to capture vs. air. I would rather have a true air ride system with a moisture evacuation valve and not have to take it to the dealer for slight N2 leaks! When you lower the truck where does the N2 go?I believe the RAM system is a closed system, no way to drain it. Moisture should never be in the system unless a seal is broken somewhere.
