scottmoyer
- Nov 13, 2020
I would like to update this thread with accurate info. I called Airlift and asked about the need to pre air the bags before you add a load. They said that is not correct. I was told that the bags need to be kept with about 5psi in them to maintain shape. Before loading, they suggested that a measurement from the center of the rear wheel lip to the ground be taken, add your load, then add air to get you back to the original ride height.
It was also suggested that if the amount of squat might be known, that adding in "some" air, before loading, will decrease the amount of air needed after loading the truck. It is not true that you NEED to air up before loading and CAN'T add air after the load is in the truck.
