Follow up for some part numbers and more info -- these are from a 2019 but I can't imagine much have changed up until present, but always check for compatibility... All OEM numbers--
Heater pads--
Seat 68309557AC qty. 2
Back 68309556AB qty. 2
Seat wiring-- Drivers side 8 way powered w/non memory
68360527AD
68360516AD
Seat wiring-- Pass side non power
68377531AC
68377532AB
Heat module-- Pass side.. mounted/attached to seat base
68433906AC
You may get lucky and your Ram might be pre-wired up to the seats--- Large yellow plug under each seat-- you must check what wires it may or may not have... Lucky me, I had to add my own wiring... Use the supplied link, enter year and make..
connectors.dcctools.com
Look for XY410A and XY420A... those are large yellow plugs and compare what might be missing and add as needed...
I used AlfaObd for programming... and the seats work as advertised in the owners manual.
Adding the heated seats is not hard, just time consuming... Good luck, your Butt and Back will thank you
-=FM45=-
