Active Grill Shutter Fuse?
TreyBobo
Hello all-
My 2019 Big Horn has been randomly throwing on the CEL and the dreaded U11E9 AGS code. Well, now it is on full time. Assuming that it’s like most people and it an electrical gremlin rather than a bad part, I’m curious if it could be a bad fuse? If so, does anyone know what fuse to replace? Electrical systems are not my forte.
Antselfmadecruz
Hello all-
I have the same problem I change my active grill shutters and still have the same problem my next thing to do it change the harness connector hopefully that works for me I see A few people say that was the problem
Ratchet
Wilson, NC
A corroded active air dam connector on the driver side of the air dam assembly is a very likely culprit. It's part of the same circuit. I'd check that for signs of water intrusion or corrosion and start there.
theblet
Probably the AAD. You can remove it and clear the code. Otherwise there’s an extended warranty on it.
  • ram letter.pdf
