yankeefan31569
- Apr 21, 2020
a member here had an issue with it staying down and got a code. dealer was asking for $250 just to diagnose.What is the issue with h airdam and how would you know it’s affected.. when you’re driving you can’t see if it’s working or not, or is there a check engine light
It just throws a check engine light.What is the issue with h airdam and how would you know it’s affected.. when you’re driving you can’t see if it’s working or not, or is there a check engine light
i had a chck eng light come on brought it in to the dealer and whatever code it was told them the air dam sensor orWhat is the issue with h airdam and how would you know it’s affected.. when you’re driving you can’t see if it’s working or not, or is there a check engine light
I removed mine to, and no cell, but good to know the warranty was extended in case I ever put it back and it fails on meI'll keep it, but shouldn't really have a need for it since i already disconnected the AAD.
wow. what a-holes!Just got my letter after going rounds and rounds with corporate about them not honoring my warranty. My local dealer is great. They exhausted all sources trying to get Ram to cover it. After weeks going back and forth with Ram, apparently they're all covered now. You're welcome folks. LOL
Yup. The CEL will say AGS but it’s actually the AAD. Go figureGot the letter last week. The dealer called it "Active Grill Shutter" (AGS) and it was causing a check engine light. Since it was still under warranty they replaced it for free!
Doesn’t seem likely but yeanow they need to adress the rear windows
