I think I found it...
X3 Series Black Front Skid Plate - Part Number DRAM40-SKID (DRAM40SKID) by Torxeâ„¢. Available in Exterior Department at www.carid.com
www.carid.com
Edit: Weird that the link I attached says "security check". For those who don't want to click the link, I found this part on the carid website. Their part number for this is mpn4934188233.
confirm, that is the one. Wow I got lucky with the free shipping back in January. Didn't do anything with it until 2 weekends ago.
At $142 tax included It felt like a good option to mess around with, back then I tried to figure out how much it would cost to make one from a sheet of steel, some angle or L brackets, paint, etc and i was coming up around $100
This is a true skid plate, heavy, can't confirm what gauge but its thick
So from the pictures you see what I did to modified it. My skills are very basic so its easy to make it work. Tools used, grinder and drill. And maybe a couple of longer bolts.
I cut some of it on the sides, maybe a little too much - it gave me some room incase I need to adjust or remove the hidden under the lower grill light bar that I have
it mounts to the where the electronic air dam used to mount but I had to drill 2 new holes on the plate itself
I drilled 2 holes to the bumper and it currently seats inside of it for better support with the help of a piece of metal square tubing which might not be necessary but I had it handy and seem like it help the plate seat better and flush against the inside bumper lip - I might bring the plate from inside the bumper to out down the road.
I found this pic - with its matching bumper it should look similar to it but as you can see, it would still not cover the engine entirely and in fact it might leave a bigger space uncover - since it only goes as far as where the electronic air dam mounts to
