Do they rub at alll?
Went with the rough country vertex. Hopefully all will be good there.One thing I don’t recommend. Is the eibach coilovers. First set had a squeak to them, now the second set just stated. Barely hundred or so miles on either.
It’s going back again, eibach supposedly had a fix for it. So we’ll see. The ride quality is nice and they look good…. Just the squeaking gets annoying as hell
Here is mine , 8 inch lift running , Nitto Recon Grapplers 37 13.50 22
Pretty sure I follow you on IG. Bad *** truck.
Truck looks great. I have a 2021 Laramie crew cab w 6'4" bed, 6112's on the front, clip set to 8, off road package, and original suspension in the rear and the truck isn't high enough for me. Would anybody know if I can put spacers on top of the Bilstein 6112's in the front without running into differential troubles? I'd have to use spacers in the rear too to bring it level I guess. Looking to put 35's KO2's on Blitzs all the way around.
You’ll run into all kinds of issues, angles on your cv axles and control arms. I wouldn’t recommend it.
