8” lift with what size tires?
Marty313
Does anyone have an 8” lift and what size tires/wheels you running?
My 35’s looks small now, I am thinking maybe 37 mid grapplers on my stock wheels.
I believe there is a Ram on custom offsets gallery running that exact setup. Give it a look. Truck is stout. I believe it’s a red bighorn if I remember correctly.
I just checked that out…. Looks like 37’s is the way to go…. Trucks look huge and tires fit nicely
One thing I don’t recommend. Is the eibach coilovers. First set had a squeak to them, now the second set just stated. Barely hundred or so miles on either.
Them vertex look good… I’ve read a lot of good about them. Might go that route next if these don’t get resolved
Personally I’d do 38s at least with an 8 inch lift. I have a 5ish” lift on 37s and I kinda think it would look better with 38s, so if you’re adding another 3” then 38s for sure E129D587-71BB-434A-9666-487B353AC25A.jpeg
Truck looks great. I have a 2021 Laramie crew cab w 6'4" bed, 6112's on the front, clip set to 8, off road package, and original suspension in the rear and the truck isn't high enough for me. Would anybody know if I can put spacers on top of the Bilstein 6112's in the front without running into differential troubles? I'd have to use spacers in the rear too to bring it level I guess. Looking to put 35's KO2's on Blitzs all the way around.
I just don't know if I can put spacers on top of the Bilstien 6112's w the clip set to 8.
You’ll run into all kinds of issues, angles on your cv axles and control arms. I wouldn’t recommend it.
