Hi all, first time owning a 4wd vehicle; had awd suvs prior. I went to the Sierras this last weekend and the roads seemed a bit wet, so I turned on 4wd auto in case there’s slippage. I noticed, mainly on turns, that there’s a whirring noise. Same seems to happen on 4wd high. Is that normal?
I’m in Northern California and it’s been a dry season so far, so I haven’t needed to use 4wd (always using 2wd). Here’s a video where you can hear; bear in mind it’s dry pavement..
Also, when should I use 4wd auto vs high vs low?
