jeffrey5679
- Oct 2, 2020
I removed the old seal. I wonder if only using the new gasket will be an issue?Yup. That’s what I used. I applied it over the factory seal. Just tighten all four screws gently and u should be fine.
Home DepotWhere did you get the seal?
I am also wondering what size the bulbs are for the backup lights in there? I have some spare T-10 size bulbs.
Take it off... otherwise you're not actually changing anything. I have seen this "fix" talked about but have not done it personally. The stock gasket does look pretty mediocre, but I have a hard time believing a longtime auto manufacturer used ineffective material for a water sealing gasket. Unless mine actually leaks, I don't plan on touching it. Not to mention doing this could void any warranty coverage in the event of a leak up there.
Yup, took me way to scrape mine off. Used a piece of plastic I trimmed to fit and some goo goneFor anyone doing this, the original gasket does not just peel off. Plan on sitting down and taking 10-15 minutes to remove it. Pretty sure I used a flat head screwdriver to scrape it off.
How long have you had the new gasket on? Any leaks?Same here, scraped off the old foam gasket then used Goo Gone to clean it up. Like others have said it takes some time but its worth doing it right.
Nope. You need to remove the old gasket to apply the new one.I removed the old seal. I wonder if only using the new gasket will be an issue?
The bulbs in the CHSML are T-15.Where did you get the seal?
It hasn’t been a week yet so it’s too early to tell. Plus no rain here yet and I haven’t washed it since.How long have you had the new gasket on? Any leaks?
I’m in the Pacific Northwest. Raining daily. I’ll let you know, I just did mine.It hasn’t been a week yet so it’s too early to tell. Plus no rain here yet and I haven’t washed it since.
2 days of rain. No leaks so far.I’m in the Pacific Northwest. Raining daily. I’ll let you know, I just did mine.
