36Degrees_North
- Aug 16, 2022
Finally had some time to install my 36 Degrees North Overland 1/2 inch front spacer. These are designed more for the snap ring adjustable front shocks so you can run less preload on the spring but still keep the lift height. I plan on running 5100s down the road but wanted to see how these would work on a stock strut assembly. Other then fighting a stuck upped ball joint install is relatively painless the aluminum plate just sandwiches between the top hat and the coil bucket. Before I had 37 inches from the ground to the center of the wheel well after I have a little over 37 and a half inches.
