33s or 34s with a Level? HELP!
Tommymoe5
I have a Ram ORG with the Readylift 2” kit.Trying to decide between 33x12.5 r18’s or 295/70 r18’s with a 0 offset. Any pictures or suggestions on if either one will fit and what looks better??
djevox
VP of Creative Thinking
MD
With ORG you have the equivalent of a 3” front lift (over a stock non-ORG), which is pretty close to perfect lift for 35’s. My vote is for the 34’s because they fall closer to the 35’s and 3”+ lifted look and also because they are 11.6” wide and that is going to be slightly more fuel efficient when compared to the 12.5” width.
Tommymoe5
@djevox thats what I was leaning towards too, I just wasn’t sure if with the 0 offset of a 295/70 would fit without any rubbing. Not many ppl that I’ve found are running that size. Do you think it would fit? The tires I’ve found are roughly 34.5x11.5 range.
djevox
MD
I don’t know without measuring at different points through the steering range. I used This Guide and estimated the lift size by calculating height difference to fenderwells from the hub center. It’s a pita, but if you have ample clearance, then you’ll know your estimations are fine.
ayoslickxd
i have 305/70/18 and theh fit my rebel easy with fox 2.5 in front
DenCoRam
I have 295/70/18 on stock wheels (18x8) with ~1.25" level over the rebel suspension and 1.5" wheel spacers. I had to remove the husky mudflaps, the little plastic mud guard, and bend back the pinch weld/zip tie back the fender liner at the rear of the wheel well. Rubbed when turning and compressing the suspension, like turning into a driveway up the angled curb. Not sure the width on the wheels your'e choosing, but most 0 offset wheels I've seen are 18x8.5. My setup would be roughly equal to an 18x8.5 et -5. With the extra .75" of you level, you might be fine.
BamJamRAM
I was thinking about running this exact same setup on my 2019 Rebel exept i plan on going the full 1.8 " level with the Bilstein 5100s (I believe it's the most you can achieve on the rebel with that level)...
So final setup would be OEM rims, Rough Country UCA, Bilstein 5100 w/ 1.8" level (5th setting), BORA spacers 1.5" in front 1.75" in rear, and 295/70R18 BFG KO2. I believe these tires are the exact same height and width of the Toyo OC AT2s (34.3×12).
Do you think I will have any of the same rubbing issues that you came across with the additional .6" from the Bilstein 5100s?
