I don’t know without measuring at different points through the steering range. I used This Guide and estimated the lift size by calculating height difference to fenderwells from the hub center. It’s a pita, but if you have ample clearance, then you’ll know your estimations are fine.@djevox thats what I was leaning towards too, I just wasn’t sure if with the 0 offset of a 295/70 would fit without any rubbing. Not many ppl that I’ve found are running that size. Do you think it would fit? The tires I’ve found are roughly 34.5x11.5 range.
I was thinking about running this exact same setup on my 2019 Rebel exept i plan on going the full 1.8 " level with the Bilstein 5100s (I believe it's the most you can achieve on the rebel with that level)...I have 295/70/18 on stock wheels (18x8) with ~1.25" level over the rebel suspension and 1.5" wheel spacers. I had to remove the husky mudflaps, the little plastic mud guard, and bend back the pinch weld/zip tie back the fender liner at the rear of the wheel well. Rubbed when turning and compressing the suspension, like turning into a driveway up the angled curb. Not sure the width on the wheels your'e choosing, but most 0 offset wheels I've seen are 18x8.5. My setup would be roughly equal to an 18x8.5 et -5. With the extra .75" of you level, you might be fine.
