33 x 12.5 on factory 22s
My Limited has air suspension 33x12.50R22 on stock rims works good
For anyone wondering what 305/45/22 looks like on a limited. These are alo baja boss at. They look mean even in an xl tire. They look better in person
for sure. I can tell you so far they are very smooth and no louder than the stock pirellis. So far they are great. Also have links up front from suspension supertore.1000025348.jpg1000025342.jpg1000025343.jpg
  • Like
Reactions: EAB
Hey guys, relatively new to the fourms so thought I'd say hi and possibly help some other newbies who may be lost searching different threads. I been looking for several week now for a straight answer on if I could fit a 12.5 wide on my 2021 limited without a lift, level or spacers and I couldn't get a straight yes or no either way...WELL I'm here to tell you that you infact can fit a 33 x 12.5 r22 on your trucks factory rims without it rubbing any of the steering components! I did a test fit first in "normal" and it cleared lock to lock however to be safe and since the wheels were off I drilled a tiny hole on the inside corner of my inner fender and used a tie strap to give me even more clearance. Hope this helps anyone that was thinking of a similar mod....here's a few pics dont mind the dirt 😉
Newbie here :) I haave a 2024 ram 1500 Laramie with 22" wheels does the 33 wheels give you any more tire wall height so you don't hit the curb.. Thanks in advance
I don't think they are taller. The way they fit the rim they have like a little bulge that I think will help but I try and stay away from curb's.
Check out tiresize.com. You can compare tire sizes, wheel offsets, etc. Super helpful.
