Should just be at full lock on the UCA. If you want to stay with stock wheels just add about a 1/4” spacer and you should be ok.Trying to find suitable rim to fit. Cause on full steer it rubs tiny bit with stock rims. To he expected with 35x12.5r20 Ridge grapplers
yeah I bought them already for temporary solution we're going to put them on in a few hoursShould just be at full lock on the UCA. If you want to stay with stock wheels just add about a 1/4” spacer and you should be ok.
As far as new wheels, anything 0 or with a negative offset will rub. There is a small metal tab that protrudes underneath the factory splash guard. You can trim that off and then usually be in good shape.yeah I bought them already for temporary solution we're going to put them on in a few hours
Do the fender modTrying to find suitable rim to fit. Cause on full steer it rubs tiny bit with stock rims. To he expected with 35x12.5r20 Ridge grapplers
Don't know what that is.....Do the fender mod
Post some more pictures! She looks amazing. I love seeing these lifted on stockers.Trying to find suitable rim to fit. Cause on full steer it rubs tiny bit with stock rims. To he expected with 35x12.5r20 Ridge grapplers
This truck looks perfect in my opinion.Trying to find suitable rim to fit. Cause on full steer it rubs tiny bit with stock rims. To he expected with 35x12.5r20 Ridge grapplers
