3.5" readylift done
ksn240
Trying to find suitable rim to fit. Cause on full steer it rubs tiny bit with stock rims. To he expected with 35x12.5r20 Ridge grapplers
Should just be at full lock on the UCA. If you want to stay with stock wheels just add about a 1/4” spacer and you should be ok.
stippLe
Texas
yeah I bought them already for temporary solution we're going to put them on in a few hours
ksn240
As far as new wheels, anything 0 or with a negative offset will rub. There is a small metal tab that protrudes underneath the factory splash guard. You can trim that off and then usually be in good shape.
M
Mdegen93
Guest
Don't know what that is.....
Had to do it to mine to run a -12 22860
RichM1983
I love those stock Laramie Sport wheels with the 35" tires. I can't imagine you'd find a better wheel in my opinion.
bigdaddymac
Dallas, GA
Looks great! Mine goes in Wednesday for 3.5” lift and Ridge Grappler 35x12.50r20 on Fuel Sledge wheels w a 0 offset.
Boomer
DO NOT USE SMALL WHEEL SPACERS!!! They are not hub centric. You do not want all the trucks weight on the lugs. It is very dangerous. Research it.
