3.5” Readylift kit installed
410DelmonicoSport
Finally had some time at work to install my lift. Went with the Readylift 3.5 with control arms, but opted to skip the 2” preload spacer and install Bilstein 6112s. Used Bilstein 5100 shocks for the rear. For wheels and tires I did the Toyo Open County AT3 35x12.50 and the Asanti Workhorse in a 20x10 -20 offset. It rubbed a little bit, but not too terrible. I am absolutely in love with this setup so far as it rides so much better than factory.
Which setting did you put the 6112s on? Looks really nice.
I put them on #6 to get the 2” of lift I would have gotten from the preloads. Although, in all my excitement, I forgot to measure after it was done.
One more question, did you use the top strut extension?
Truck looks great! Thanks for the info
So if I am following. This kit along with bil 6112 at #6 would be what you used?
No, I used the full Readylift 3.5” kit, not the leveling kit. You can level it with just the Bilsteins and control arms if you’re not looking to do anything to the rear.
But you left out the coil spacers in front right? You just used control arms and top hats on strut?
